Thunderjet kit on a CV carb
Old Jan 25, 2012 | 08:19 PM
blair's Avatar
blair
Default Thunderjet kit on a CV carb
I was thinking about installing a Thunderjet on my CV carb . My motor is not stock. Has any one used them before and what were your results . All info would be appreciated. Thanks
Old Jan 25, 2012 | 08:22 PM
omgtkk's Avatar
omgtkk
When you say your motor is not stock...can you be a little more specific. Unless you are running a pretty wild set-up, I doubt you need a thunderjet.
blair's Avatar
blair
The Cv carb has a dynojet kit in it
Old Jan 25, 2012 | 08:27 PM
blair's Avatar
blair
Heads done , ev27 cam , 10.5 to 1 kb pistons , single fire ignition and a bunch of other stuff. I had the Thunderjet lying around , just wondering about how it would work
Old Jan 25, 2012 | 08:31 PM
qtrracer's Avatar
qtrracer
I have used them in other applications and on a S&S carb. I would think the the CV would work as designed without another vacuum operated system in the mix. The thunder jet uses vaccum to operate and that vacuum that is uses may take away from the vacuum the CV slide needs to operate as it should. Maybe I'm all wet.
Don the duck
General Topics/Tech Tips
Sep 6, 2017 10:35 AM
Ozark Joe
EVO
May 3, 2017 07:35 PM
gsxrboy96
Evo Era Parts
Jul 15, 2012 08:46 PM
bsabers
Exhaust System Topics
Oct 1, 2009 03:48 PM
mcfaddenfxdx
Dec 5, 2007 01:36 PM
