Engine compression
Old Jan 22, 2007 | 03:39 AM
HTRAUD's Avatar
HTRAUD
Default Engine compression
Is 10.6:1 compression too much for street motors. I was looking at the GMR website and their power package 2. It sounds good, but is that compression too much for a RK street bike. Also what other issues would you run into - starters, clutch etc
Old Jan 22, 2007 | 04:53 AM
Oldtimer of NM's Avatar
Oldtimer of NM
Default RE: Engine compression
A lot depends on the cam(s) you have. More radical valve timing reduces the compression pressure at low speeds where detonation is more likely to be a problem. This will also help lower the load on your starter.
Old Jan 22, 2007 | 10:53 AM
dog155's Avatar
dog155
Not at all,it all depends on the engine package.My 10:8 to 1 motor runs like a stocker.If your going to run a lot more HP than stock,you certainly will need to beef up the clutch.The starter can be a stock HD,just upgrade your cables and make certain the grounds are in top shape.Most all the big inch motors come with compression releases installed.
Ben E
Nov 25, 2011 06:19 AM
Qonrad
Exhaust System Topics
Nov 16, 2011 05:25 AM
Bluehighways
Jan 30, 2011 05:48 PM
Z06_Pilot
Aug 26, 2008 10:36 PM
05 HD Deluxe
Aug 12, 2007 10:21 AM
