Changing Handlebars
Old Sep 28, 2015 | 09:00 PM
streetbob1236's Avatar
streetbob1236
1st Gear
Default Changing Handlebars
So I got a set of handlebars cheap from somebody on craigslist. The bars are great, and look great on the bike, only problem is that the wires and cable don't quite reach to the 16" bars. The handle bars on it now are not the stock ones, but are only 12". Is there a cheaper alternative to the $180 cable/wire kits from companies like Burly? I'm willing to do more work to save some money, just need a starting point. Any help is appreciated.
Old Sep 29, 2015 | 08:46 AM
Sturgis67's Avatar
Sturgis67
You can buy the cables individually, and splice the wires by hand. That's what I did. Cut wires in the middle and splice the length you need. Color doesn't matter this way because you still have the right color on each end. Make sure to use heat shrink and solder the connections.
Old Sep 29, 2015 | 08:49 AM
J929626's Avatar
J929626
If you go this route then remember to stagger the splices to keep the bulk down.
Old Sep 29, 2015 | 09:40 AM
Sturgis67's Avatar
Sturgis67
^^^absolutely correct.^^^
If not it's a PITA Getting wires through the bars.
Old Sep 29, 2015 | 10:28 PM
streetbob1236
1st Gear
How much does this cost in comparison? Where should I get the cables/wires? Do you know of any good videos or instructions I could go off of?
Burbur2
Feb 8, 2019 08:49 AM
Dillon06SG
Jun 20, 2018 07:59 AM
derk8088
Oct 10, 2013 06:09 AM
jeh83
Mar 23, 2011 01:53 PM
shepdog
Ironhead
Jun 28, 2009 05:19 PM
