wheels
Old Mar 16, 2016 | 06:43 AM
bootlg13@yahoo.com's Avatar
bootlg13@yahoo.com
Stage II
Default wheels
does anybody know if rims from a 2012 ultra classic with anti lock will fit on 2005 ultra classic not sure if i have antilock
Old Mar 16, 2016 | 06:49 AM
QC's Avatar
QC
Welcome to the Forum from Colorado!
You can probably make them fit, but they will not be a straight swap.
You do not have anti-lock brakes.
Old Mar 16, 2016 | 09:07 AM
multihdrdr's Avatar
multihdrdr
Front Rim only (2012 Rear too wide)
Swap your 11.5" rotors with the 2012 11.8"/300mm rotors or get 08-later "Touring" brake calipers (Brembos) to use the 11.8"
Get 08-later 25mm axle/spacers change bearings to Std Non-ABS bearings (still 25mm ID x 15mm wide)
OR
Change bearings to 1" (21mm wide OEM on your 2005 or get Non-Std 15mm wide), re-use your 1" axle with "different" spacers.
This may help
https://www.hdforums.com/forum/touri...l-install.html
Old Mar 16, 2016 | 01:25 PM
bootlg13@yahoo.com
Stage II
Default wheels
thanks for the info think ill stick with what i have and look for a straight swap wanted to get away from spokes to a more solid rim
Old Mar 16, 2016 | 01:48 PM
jmaniace's Avatar
jmaniace
All you have to do is change out the bearings and it will be a straight swap. 2012 has 25mm and your bike has a 1" shaft.
Wyatt MacGregor
Feb 26, 2017 09:54 PM
wideopen4life
Jan 29, 2013 07:06 PM
rugger
Apr 19, 2010 04:34 AM
Blu02
Wheels/Tires
Mar 25, 2010 04:36 PM
DrDrift
May 16, 2009 10:08 AM
