Rake angle...
Old Jun 2, 2017 | 11:52 AM
Ajay V's Avatar
Ajay V
Stage I
Default Rake angle...
Is it possible adjust the rake of a street bob
Old Jun 2, 2017 | 04:15 PM
Stick_FSMC's Avatar
Stick_FSMC
It can be done, but you have two options.
1. Cut the frame and rake the neck, then weld it back again. It's been done many times over the years, but if you do not have the correct equipment and skills, it's easy to destroy your bike.
2. Buy a set of triple trees/front end that either have adjustments in them, or that have a +or- rake already. This is the easiest option and there are many vendors out there that will sell you bolt up kits. There is also less risk to your motorcycle.
Old Jun 2, 2017 | 05:13 PM
BuzzCap7's Avatar
BuzzCap7
Out of curiosity my friend, why would you want to do that with a Street Bob?
BuzzCap7
Old Jun 2, 2017 | 05:35 PM
Max Headflow's Avatar
Max Headflow
Plus you can raise or lower the front or rear of the motorcycle to change the rake.. Essentially changing the angle of the whole frame.
Old Jun 3, 2017 | 10:39 AM
multihdrdr's Avatar
multihdrdr
Let's give it a name...Neck Angle or Steering Head Inclination
Also Raked Bearing Cups might be appropriate or Not (depending)
BTW, for all those who don't know...Raked Triple Trees have the opposite effect on Rake and Trail than changing the Neck or Stem (bearing cups) Rake
MegaFauna
May 2, 2017 09:08 PM
agiffey
Jun 15, 2012 12:58 AM
The Spook
Custom Models
Dec 8, 2011 05:26 PM
SGTsapper
Dec 28, 2006 02:57 PM
DynaDogg
Aug 26, 2005 11:35 PM
