Fouling plugs
Old 06-20-2017, 09:01 PM
TroyCreese's Avatar
TroyCreese
TroyCreese is offline
6th Gear
Default Fouling plugs
New to the forum, trying to find some answers. I have a '94 Electra Glide and the other day had to have it towed home because it was only running on one cylinder. I recently had a rebuilt S&S super G carb put on (jetted down) with the plan of ordering new pipes this week. I've put a couple hundred miles on it since the carb was put on and everything was fine, running good and when I checked the plugs everything looked good, mixture looked good. Tonight I finally got a chance to check for spark and that looked good so I checked the plugs and found that the front one was fouled, black as coal. Replaced the plug, fired it up and it sounded good. Took it down the road about 1/8 mile and still running good until I made the u-turn to come back when it started to sound bad again. Got home, pulled the plug, black as coal again. Any insight would be greatly appreciated.
Old 06-23-2017, 03:44 PM
Knutson Boltz's Avatar
Knutson Boltz
Knutson Boltz is offline
check out the web for plug reading 101, tell you what you need to know. was the plug in question wet or dry/?
since its fouling so fast i bet you need new rings
Old 06-23-2017, 04:47 PM
TroyCreese's Avatar
TroyCreese
6th Gear
The plug was dry both times. The engine only has about 10k miles on it. It is a '99 crate Harley crate engine that was put in about 5 years ago.
JohnnyC
EVO
37
10-05-2019 04:27 AM
Delawaredave
EVO
24
07-02-2014 04:55 PM
Razorback Rob
12-31-2008 09:19 AM
PMZ XL 1200
04-19-2007 08:58 AM
KenM
Exhaust System Topics
06-03-2006 10:16 PM
Quick Reply: Fouling plugs
