Recommended spark plug ?
Old Jun 29, 2014 | 11:48 AM
Delawaredave's Avatar
Delawaredave
Default Recommended spark plug ?
Newbie. 1989 FLHS. I believe stock with exception of S&S carb.
Bought bike with Champion 5R6A plugs. This is also plug called for in service manual.
Just curious if anyone recommends any different plug specification (hotter or colder, iridium, etc - don't want to start a "plug brand debate")
Thanks !
Old Jun 29, 2014 | 12:00 PM
Uncle G.'s Avatar
Uncle G.
I've always used the H-D 5R6A (Champion RN12YC) myself. Is there some reason you want to use something else?
Old Jun 29, 2014 | 12:19 PM
Delawaredave
First had no spark - bad coil - replaced.
Now bike is running rough - bogs down on acceleration and sometimes seems to backfire back through carb. Thought next step should be plugs and wires - didn't know if S&S carb would affected recommended plug.
Any brand of wires recommended and website to buy ?
I'm on a budget (read:cheap)......
Thanks !
Old Jun 29, 2014 | 12:38 PM
Hackd's Avatar
Hackd
This the same bike that's been sitting a year????
I'd be checking the intake manifold seals before I started messing around with the spark plugs.
Old Jun 29, 2014 | 01:04 PM
johnjzjz's Avatar
johnjzjz
in my shop we only use ( iridium sparkplugs ) they last 100,000 miles and perform at a much better rate than the fishing pole weight a champion plug is
Old Jun 29, 2014 | 02:33 PM
Delawaredave
Same bike that has been sitting - I'll check intake seals first - thanks.
Old Jun 29, 2014 | 04:22 PM
Spanners39's Avatar
Spanners39
Same here......
Old Jun 30, 2014 | 11:53 PM
Bumpandrun's Avatar
Bumpandrun
Well this showed up with perfect timing. Lol. Now that I have the ole pig jetted pretty well. What part number and brand plug do u rocommend.john
Old Jul 1, 2014 | 12:03 AM
Spanners39's Avatar
Spanners39
Here is a good link when needing plug advice http://www.ngksparkplugs.com/part_fi...es/default.asp
Old Jul 1, 2014 | 12:10 AM
D_gyver's Avatar
D_gyver
hands down NGK no one makes a better spark plug.
BPR5EIX-11 is the plug I use in my evo.
