Help - Extra Washer after bar swap
Hey guys. I know this is a long shot, but here it goes. I have an extra 5/8" OD flat washer that I THINK came from the bike. I swapped the stock bars on my 2009 FXDF with Big Al's 8" risers and bars. I also swapped the clutch cable, brake lines and throttle cables. I am racking my brain and can't think of where it came from (if it came from the bike). Am I overthinking things? I'll be honest, this may have been stuck on my magnetic tray from before the swap project. Thanks in advance.
baba booey (08-14-2018)
Put in in the mop bucket in the corner that all the extra nuts, bolts washers and clips go in. One day it will be so heavy a wheel will fall off. Then after digging through all the stuff in the bucket, use it in the repair.
Is it one of the washers for the ground wire?
