2005 Sportster getting one hard click
Old 03-10-2019, 05:04 PM
Matt Hill's Avatar
Matt Hill
Matt Hill is offline
Stage IV
Default 2005 Sportster getting one hard click
** 2005 Sportster 883R**
Hello ladies and gents. I’m trying to get my bike started for the season, after being in my garage all winter, and I am having issues. When I press start, I am getting one hard click then nothing. All lights and signals are working.
When I first tried, it was obvious my battery needed to be replaced. So I did that. I also tried to detach the cables and retry that. I also replaced my fuses and starter relay. None of these worked.
Any other ideas I may be able to try on my own? Thanks in advance for your help!
Old 03-13-2019, 04:09 PM
enodrano's Avatar
enodrano
enodrano is offline
The click you hear is from the Starter Relay. If it clicks then it is working and does not need to be replaced. I suspect the starter solenoid is bad or needs to cleaned/rebuilt. All electrical connections will corrode over time. I would first clean the battery contacts, starter contacts, and internal solenoid contacts before replacing anymore unnecessary parts. The following video will help you out.
Good Luck!
Old 03-16-2019, 08:02 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Dan89FLSTC is offline
Received 8,531 Likes on 4,631 Posts
Without hearing it, there is no way to determine what the problem is.
The click you are hearing could be the relay, but it could also be the solenoid that you are hearing.
The relay will be a very quiet sound, the solenoid will be a loud clack.
Make sure all battery cables are clean and secure, you must follow the factory service manual for the proper connection procedure.
Old 03-16-2019, 08:57 AM
Matt Hill's Avatar
Matt Hill
Stage IV
Thank you guys for the reply’s. The sound I was heading was one loud clack. I was able to clean out some of the cables and tighten them and was able to finally getting it to turn over. Thanks again!
Old 03-16-2019, 09:03 AM
multihdrdr's Avatar
multihdrdr
multihdrdr is offline
Received 2,239 Likes on 1,815 Posts
Boy, did I misread this Thread Title ... I thought you were just posting about your exciting 2005 Sportster ... maybe new to you
I read it as ... "2005 Sportster ... getting one hard dick"
My bad
Old 03-16-2019, 09:27 AM
Matt Hill's Avatar
Matt Hill
Stage IV
My bad
HAHA! I guess I could have phrased my title better.
Dopey
07-01-2019 12:07 PM
sech4787
04-10-2018 05:24 PM
1abrat
Electrical/Lighting/Alarm
11-12-2016 07:11 AM
Snowman88
04-22-2014 04:12 PM
cobo_pro
Exhaust System Topics
03-23-2008 08:54 PM
Quick Reply: 2005 Sportster getting one hard click
