Handlebar help...
Old 05-15-2019, 04:22 PM
RootbeerKing's Avatar
RootbeerKing
RootbeerKing is offline
Default Handlebar help...
I've researched so much, I need to be in a bar. I need to get my arms out a bit so, I've narrowed in down to WO578 10" Bagger Appers or Khrome Werks 12" Bobbers. 2017 Ultra Limited...any advice?
Old 05-16-2019, 07:16 AM
fordhd2005's Avatar
fordhd2005
fordhd2005 is offline
I don't have any advice... I ran a set of the WO578's on my ultra for about a year and they were fine. The best part was not having to extend anything. Later I swapped them out for WO577 12.5" and I like those a lot better. Needed an extended clutch and brake line and the wire extension.
Old 05-21-2019, 11:17 AM
Guitarman_sg's Avatar
Guitarman_sg
Guitarman_sg is offline
I just did 10" KST Mayhems on mine. Look like the Yaffe Monkey bars but about half the price. If you don't need the heated grips cut the black plug before running your wires, makes it way easier to pull. The 10's put me right where I wanted to be, took my hands up and forward but I am still behind the fairing. hope that helps. Here is a pic of the bars when I got them done.
Old 05-23-2019, 02:14 PM
RootbeerKing
Two things...first Thanks Guitarman for the reply. I just ordered the 10" KST Six Bend Kickers. I'm too old for pointed objects. Also, I'm assuming you're a guitar player. I play bass. Thanks again.
JMc
Old 05-23-2019, 07:17 PM
Stroked16's Avatar
Stroked16
Stroked16 is offline
12" bars are right in the middle of the stock mirrors, so be sure to consider that. I'm 5'10" and wish I went with 14" bars instead of 12"
you can run up to 14s without extending any cables/wires.
Old 05-24-2019, 09:22 AM
Chunker's Avatar
Chunker
Chunker is offline
I had Wild One 575 on my 11 Limited and 578 on the 15 Limited. I liked the position and comfort level of both. Note, 575 won't fit on Rushmore models or I would have used them. I did my own internal wiring with heated grips. Took time but worth it.
Old 05-24-2019, 09:56 AM
RootbeerKing
Thanks for all the input and I should have stated that this is for an Ultra Limited, so mirrors are not an issue.
Old 07-21-2019, 06:46 PM
Gumby256's Avatar
Gumby256
Gumby256 is offline
What did you end up with? Do you like them?
Old 01-29-2020, 11:36 AM
Harleylife1's Avatar
Harleylife1
Harleylife1 is offline
100% Wild 1 all the way. Had them on all of my bikes and they are the best out there. High quality American made stuff
hoggzzer
2014-2023 Touring Models
05-05-2018 07:02 AM
Thatguy423
General Topics/Tech Tips
03-18-2017 07:39 PM
bigrobtemp
08-06-2015 07:34 PM
dlpuette
04-30-2013 01:29 PM
Fire-Medic
10-10-2011 11:07 AM
Quick Reply: Handlebar help...
