problem with cluthch adjustment
Old Jul 10, 2019 | 09:09 AM
pulledfade's Avatar
pulledfade
Stage I
Default problem with cluthch adjustment
i recently got an electraglide because my fatboy was in the shop and they were pessimistic about a quick turnaround. Started to adjust the clutch as i've done on the fatboy twenty times.after turning the adjustment screw in till it touched and backing it off 3/4 turn, i tightened locknut and proceeded to remove the freeplay from the cable.i turned the cable adjuster away from the locknut and before the slack betweem the hand lever and the ferrule was 1/4" the cable adjuster came loose. cannot get the cable back to where it was. Any suggestions would be appreciated
keith t
Jun 29, 2016 10:43 AM
eglintonboy
Mar 16, 2014 12:30 PM
auburn08
Nov 30, 2010 02:24 PM
dugan
Apr 29, 2010 12:53 PM
srigas
Dec 17, 2009 08:57 AM
