Throttle backwards
Old Mar 19, 2021 | 07:32 PM
GAH003's Avatar
GAH003
5th Gear
Default Throttle backwards
Good evening all. I just had some upgrades done to my 2019 Ultra Limited, one of which included new bars. It appears that my throttle is acting backwards. Full throttle is idle and vice versa. Anyone have any clue where to start? Thanks in advance.
Old Mar 19, 2021 | 07:35 PM
Jackie Paper's Avatar
Jackie Paper
That sounds cool, so you twist it fwd to go that direction. Years ago on the first heal and toe shifter, I always thought Harley had that backwards. You do have it on correct side?
Old Mar 19, 2021 | 09:55 PM
NODYNA's Avatar
NODYNA
You have throttle by wire. My guess is the tbw wires were reversed when the wiring was extended.
Old Mar 20, 2021 | 01:25 AM
GAH003's Avatar
GAH003
5th Gear
yea that was my thought to. Now the fun of trying to figure out which one. Thanks for the reply!
Old Mar 20, 2021 | 01:26 AM
GAH003's Avatar
GAH003
5th Gear
HAHA! Yea it’s on the right side
Old Mar 20, 2021 | 06:20 AM
LoupGarou's Avatar
LoupGarou
I would have to think that the connector would be "keyed" to prevent reversing the connection, examine them closely, if one is backwards it should be easy to detect. I can't imagine what else could have caused this.
Old Mar 20, 2021 | 07:11 AM
NODYNA's Avatar
NODYNA
You didn't say who did the install. If wire extensions were used it's possible the wires were reversed in the connector. If they were pieced out reversal possible also. Check for the connector at the base of the bars for matching wire colors. If the new bars are real high the connector may be in the bars.
Old Mar 20, 2021 | 08:07 AM
1999 flstf's Avatar
1999 flstf
when you start it is running wide open and you have to go full throttle to get it to idle. do you still turn the throttle normal or is that backwards also.
Old Mar 20, 2021 | 08:37 AM
GAH003's Avatar
GAH003
5th Gear
Throttle turns as it should. The bike wouldn’t start and after tinkering with it I found that when you give it full throttle the EITMS turns on/off. That’s what clued me into a problem since normally you roll the throttle away for that, obviously. I then tried starting it at full throttle and it fired right up. Wiring connections so far seem correct. Will continue the hunt tomorrow but I assume it must be a wire issue somewhere. Thanks for your replies!
Old Mar 22, 2021 | 01:52 PM
MCSarge's Avatar
MCSarge
If they depinned the connector plugs to do the wiring they may have put a wire in the wrong hole in the plug when they put it back together. Check the connector at the factory end in the fairing and make sure the wires going toward the grip all have the same colors in the same spot on the connectors.
