Plug gap?
Old Jun 26, 2021 | 05:44 AM
98hotrodfatboy's Avatar
98hotrodfatboy
Now I see why you have "LQQK_OUT" as your handle.... Thanks brother, I didn't really want to get into it with this douchebag again... He's always got to stir some kind of s***..
I really think he needs to be banned from this Forum...
Old Jun 29, 2021 | 04:10 PM
hrdtail78's Avatar
hrdtail78
Originally Posted by MidnightXL883
How much impact does spark plug correct gap make? Attached are the ones I just replaced. You can see the right plug is gapped way too close.
You can listen to internet experts repeating other's information all day long. Or you could go with manufacture recommended gap that is in the book. Get away from stock engine and gap is best found by power output. Sometimes .020 is best power. All depends on the build.
Old Jun 29, 2021 | 04:18 PM
Clammy's Avatar
Clammy
I'm running NGK Iridiums, one range colder than stock (DCPR8EIX), in Reaper's engine, which is built out to 98 ci @ 10.5:1 compression. For the past year or so, I ran a 0.035" gap. I recently replaced them, and decided to try a larger gap (thanks to reading articles/posts related to effect of spark plug gap). So, same plugs, but gapped to 0.040", and no other change to anything engine related. So far, I've picked up 2+ mpg, and she seems to pull a bit harder. So, it would seem that the 0.035" gap wasn't optimal for my build, and 0.040" is right on, or at least closer. I'm going to experiment a little with gaps, and see where the optimal gap lands.
Cheers!
Old Jun 29, 2021 | 07:37 PM
Max Headflow's Avatar
Max Headflow
I'd be real interested in what made best HP with 0.020 gap. I'd expect it to be an older points controlled bike where the coil voltage was under 10KV.
Old Jun 30, 2021 | 12:21 PM
slw210's Avatar
slw210
Probably be fine for the OP, since he never goes over 40MPH on his 883 Sportster.
Old Jul 1, 2021 | 06:38 AM
bustert's Avatar
bustert
yep, just about top out on the 883
the xls 1st gear is 60 mph on my setup
Tri-Glide14
Jul 5, 2019 10:40 PM
Rusty Axle
Shovelhead
Apr 28, 2019 09:49 PM
NSCoyote
Jul 7, 2012 11:23 PM
grippper293
Jul 1, 2007 11:13 AM
Shift_4lo
Mar 11, 2006 03:37 PM
