Method for vacuum testing
Old Apr 5, 2023 | 02:44 AM
cgmartine's Avatar
cgmartine
Red face Method for vacuum testing
I will be testing my intake manifold for leaks on my carbureted Harley-Davidson Softail. What is the best/recommended method of doing this without blowing myself up or damaging the paint or chrome? Is it by using an unlit propane one pound bottle, carb cleaner, brake cleaner, or WD-40, or is there something else that is safe?
Old Apr 5, 2023 | 05:14 AM
RANGER73's Avatar
RANGER73
Use the WD-40, you're less likely to harm the paint or rubber.
Old Apr 5, 2023 | 06:26 AM
roussfam's Avatar
roussfam
I've used propane, no mess
Old Apr 5, 2023 | 11:02 AM
bustert's Avatar
bustert
+1 mr. ross
just remember a little dab will do ya.
Old Apr 5, 2023 | 11:20 AM
98hotrodfatboy's Avatar
98hotrodfatboy
I've carefully use brake clean.. It has a a distinctive smell when burned in the combustion chambers and comes out the exhaust..
Old Apr 5, 2023 | 12:25 PM
chopper_man's Avatar
chopper_man
I use propane, zero mess.
Old Apr 5, 2023 | 08:05 PM
cgmartine's Avatar
cgmartine
Talking
Thanks. I think I will go with propane.
Old Apr 5, 2023 | 10:03 PM
MotoJockey's Avatar
MotoJockey
Report back!!
Old Apr 5, 2023 | 10:10 PM
TwiZted Biker's Avatar
TwiZted Biker
Seen propane blow a carb manifold and all completely off a bike, damned lucky it didn't catch fire.
I use brake clean with the little tube, little spurts does fine and it drops the engine out not speed it up.
Old Apr 5, 2023 | 10:47 PM
cgmartine's Avatar
cgmartine
Talking
Well sir, you just threw a monkey wrench into my plans. I wanted to stay away from brake clean because I thought it would be bad for the engine paint and the paint on the tank. Now you will have me having second thoughts about using propane. Has anyone heard of an explosion such as he has mentioned?
