General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Mask the painted area with painters tape.Mark the hole.Use center punch.Drill pilot hole.Step up to finish drill dia.Use a countersink to deburr holes.
Mike,It may aslo be a goog idea to have some kind of backing on the backside were the drill will break thru.
For example...place tape on back side as well \\;\\\\\\;and then maybe a block of wood the same contour as the back side.This way when the drill breaks thru \\;\\\\\\;the oppisite side \\;\\\\\\;of the mat'l is pressing against \\;\\\\\\;a solid surface preventing the glass from \\;blowing out.
Get a drill bit a couple of sizes larger than the hole you're going to drill. \\; \\; Hold it in your hand, and spin it to gently shave away the paint \\; into the shape of a tapered hole. \\; \\;
With the correct sized drill, slowly and gently drill through the material. \\; Take your time, and drill slow. \\; If you drill too fast, the edge of the bit will bite deep, and chip the paint. \\; Don't push too hard on the drill, or it will splinter the fiberglass as it exits the other side.
Like he said, something to back up the material you're drilling into \\;is pretty helpfull, but it has to fit tightly to the surface. \\; \\; You'd want to use something like a large half-round piece of wood. \\; Something that kinda matches the contours of the fender in that particular spot. \\;
