Drilling a hole in the fender...
I am moving my 1998 Sporty rear turn signals to a new laydown plate mount from HD. The instructions never say anything about drilling a hole to get the wires from the inside of the fender to the outside, so they can be routed thru the hollow tube, into your turn signal housing. (long sentence I know) Ive read and reread the HD instrs and there is NO way Im going to avoid drilling a hole. There is room between the top of the brake light housing and the bottom of the license plate mounting and the hole would be hid by a reflector on the bottom of the plate holder. On so Im resolved to drilling this hole out to pass thru the 4 wires.. 2 for the left, 2 for the right, turn signals. I need to pull the wires and check their diameter but lets say I had to drill a 3/8" hole. Any tips or suggestions?
bob
bob
The next biggest thing is to get the turn wires out of the fender mount holes. I can't remember if they come out of the hole with the connector still attached or not. I was thinking they do. you need to remove the taillight lens and look for the connection point.
You might consider filing a little notch in the taillight housing to allow the turn wires into the junction spot after you mount the turn signals to the plate mount. I did that to mine when I moved mine to the rear. Sorry it is hard to see in this pic, but the wires come up from the signals and into the housing at the lower corners of the taillight.
It looked to me like I removed the wires from inside the existing signals and pulled that toward the rear of the bike. Fed those thru the fender and into the 2 slots on the bottom of the arm that holds the 2 turn signals. Ive got pics... just gotta post.. Appreciate your help and ideas...
bob
bob
ok, I looked around and it looks like there is another way. In this thread, it talks about doing this and a guy says he just drilled a hole through his plate mount, the gasket and the fender. He did it this way so there isn't a visible hole.
Jersey Drew
12-04-2014 10:16 PM
section8joe
03-08-2013 09:25 AM
