General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Had one on my last bike - BMW. I did not use it very often. It is not a cruise control, but rather a throttle lock. If you are on level ground, you can use it for a bit to relax your right hand. However, it is next to impossible to adjust it so as to keep your speed steady for more than a few hundred feet. You will probably find the bike gaining speed or loosing speed. Even if you get it to stay reasonably steady, any minor change in the slope of the road will affect your speed.
The one thing it does do well is to reduce the tendency for the throttle to return to idle if you remove your hand from the throttle. You can adjust the tension so that you can lightly hold the throttle and maintain your speed. You can easily override the Throttlemeister by increasing or decreasing the amount of throttle as long as you do not have the tension set too tight.
