Help!
Old Apr 25, 2005 | 10:21 AM
freekyfrac's Avatar
freekyfrac
Stage IV
Default Help!
Yesterday I was looking at the end of the tail pipes and noticed the upper pipe looked a little wet, like it was running way rich. But the lower pipe was dry...
What is wrong?????
1994 Fatboy.....
Old Apr 25, 2005 | 11:10 AM
TrackersGlide's Avatar
TrackersGlide
6th Gear
Default RE: Help!
fuel injected?
Old Apr 25, 2005 | 02:07 PM
JBBOOKS's Avatar
JBBOOKS
Default RE: Help!
Wet with water or gas?
Old Apr 25, 2005 | 06:23 PM
Lovetoride's Avatar
Lovetoride
Default RE: Help!
Is it smoking at all? Does the exhaust smell strong?
Ryan
Old Apr 26, 2005 | 12:05 AM
Terry TK's Avatar
Terry TK
Big Kahuna HDF Member
Default RE: Help!
First of all, pull your plugs. It sounds like your talking about your rear head. If so your rear plug should be soaked. You didn't say if is was gas, oil or water.
How is the bike running. Is it coughing, dying or sputtering?
Give us some more info and I'm sure we can get our heads together and give you an idea of what is going on.
Terry
Old Apr 26, 2005 | 08:53 AM
freekyfrac's Avatar
freekyfrac
Stage IV
Default RE: Help!
Carburator,
Wet with oil, very thick like tar.... It is the rear head
It's seems to be running fine, still very strong, no sputtering
She's not smoking, if so, very very little, no strange odor
Hope I answered all the ?'s
Old Apr 26, 2005 | 08:43 PM
Nevar's Avatar
Nevar
Default RE: Help!
I'd pull the plugs clean them both, check to see if there is oil or gas on or near the spark plug hole.
Install them in different cylinders. Check the wires too. [OHM metter if possible] Clean the inside of the tail pipes [as far in as you can reach] Take her out give her a good run, let her cool down and then pull the plugs. See what you get. AND check the pipes. Your checking to see if one plug or wire was weak. And or if your carb just got a bit sticky. Front jug is always leaner than the rear.
Keep us informened. Good luck
Old Apr 27, 2005 | 09:30 AM
freekyfrac's Avatar
freekyfrac
Stage IV
Default RE: Help!
I will do it tomorrow. I hope it's a plug! She's a 94 with 7000 miles. I cant imagine anything else....
She does have some motor work though. Pistons, Carb, Cam...
I'll let you guys know how I made out. Thanx for all the help!
Old Apr 29, 2005 | 12:02 PM
freekyfrac's Avatar
freekyfrac
Stage IV
Default RE: Help!
I pulled both plugs and they both looked fine... I purchased new plugs. I will clean the pipes and try them this weekend, weather permitting.
Old Apr 30, 2005 | 08:37 AM
mikeisglidn's Avatar
mikeisglidn
Default RE: Help!
kinda sounds like a valve guide.
limeyhusker
EVO
16
Oct 2, 2014 07:45 PM
Beechnut
Jul 13, 2011 01:59 PM
MissingLink33
Aug 19, 2010 12:06 PM
trapper_canada
Jul 11, 2010 07:45 PM
ZJAvy
Jan 19, 2007 10:04 PM
