Warranty question
Generally, when you make modifications to the exhaust you need to also look at the carb or EFI to ensure you don't create a lean condition. If your bike is EFI, then save your self the trouble and spend the money for a set of pipes or mufflers. They are well worth the expense and in the end, you get the most gains. You won't gain much by trying to modify the stock mufflers.
Yeah, I know I'll have to rejet the carb but I wanna know if it voids the warranty. I haven't decided if I'm putting on new pipes or what; just lookin' at all my options.
ORIGINAL: BClem
And a small amount of exhaust relief should not cause a severe lean condition.
The relief to the exhaust by drilling/removing the baffels in stock mufflers is not nearly as much of a relief (or opening up) by installing SE slip ons or other exhausts with greater sound. So, as the exhaust is opened to breathe easier the engine ingests more air and with stock fitted jetting the engine burns a lighter mixture of fuel and air (lighter on a fixed amount of fuel) - a lean burn condition. More heat: burnt valves, blown headgaskets, preignition, dieseling, burnt oil, annealed rings, hot engine, etc, etc.
BClem
BClem
I dont know but my salesman told me to keep my old pipes incase of a warrenty issue in the future.If i was you i wouldnt worry about drilling out baffles, get new pipes and take the baffles out like i did.
David
David
the gain would be a heavier wallet. drilling is old school. it was done that way long before there was any fancy exhaust systems. drill on!!!!
