General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Good price for sure but it's 1200lbs using both. (600lbs cap each ramp) What happens when you put a 638lb bike on a single ramp? Anyone used one without issue?
"Whatever ramp you use,try to reduce the ramp angle at the bed as much as possible or you will scrap the bottom and knock off the jiffy stand spring!"
+1 or worse will hang up/get stuck, even loading on trailer......FXDL
That's why they make arched ones. Just make sure you go wide as you can. Needing to put your feet down when you're riding 4 feet in the air can be rather disconcerting.
Yep, that's why I have two arched one's when I load on trailer. Works and doesn't hang. Even at trailer height I get "disconcerted", that's why I walk it on and off. At 4 feet.....naw..., not me
A trailer wouldn't be so bad, but just about anything will get you into the bed of a trailer, even backing up to a high spot on the ground. I was thinking the bed of a pickup truck. There are probably videos of people trying (and failing) to do that.
Hey I have a ramp that hooks into 2" receiver hitch and folds up to transport. I used it to loadmy road king in my 4x4 lifted truck. Worked awesome! I have itforsaleif anyone is interested. Sold my truck so I don't need it anymore. Rated for 1,000 lbs. Retails for 700.00 will let it go for 350.00 located in Euless TX. Email jswbiker@yahoo.com if you have questions.
