SE Ignition module
Old Jan 10, 2007 | 12:29 PM
fxstcguy98's Avatar
fxstcguy98
Default SE Ignition module
I went to the dealer and ordered a SE ignition module for my 98 FXSTC and the they gave me p/n 32421-94 8000rpm and the sticker and the instructions say it's for 1994 and later FLT,FLHT, FLHR models all other 1994 1340 models require p/n 32421-85B. I pointed this out to the guy and he double checked the number in his magazine size SE booklet and swears up and down that it is correct and the sticker on the part is wrong. It doesn't list on the HD website and the newer big catalogs list 32630-96 which is a 6000rpm limit ignition. My question is, is this the right module for my bike or not? What could the difference in the modules be? And most importantly will it run right with this ignition? Shovelhead bob you still out there. HELP I'm so confused.
Old Jan 10, 2007 | 07:43 PM
Shovelhead Bob's Avatar
Shovelhead Bob
Default RE: SE Ignition module
Straight out of the book (07 SE).....
C. SCREAMIN’ EAGLE
® PRO
RACING IGNITION MODULES
For race application only.
8000 RPM Limit
32421-85B
Fits ’94-earlier FX and Softail®
models and ’93-earlier FL models.
’90-earlier models require P/N
32408-90 for proper fitment.
$124.95
32421-94
Fits carbureted Evolution 1340
equipped ’94-’99 Touring, and ’96-’99
Dyna and Softail
® models. $124.95
32420-87B
Fits ’88-’93 XL1200 models.
P/N 32408-90 for proper fitment.
$114.95
32420-94
Fits ’94-’97 XL models. $114.95
Old Jan 11, 2007 | 12:49 AM
fxstcguy98's Avatar
fxstcguy98
Thanks Bob once again you saved the day. I feel better having confirmation because I only had two sources and couldn't find anything on the internet.
Old Jan 18, 2007 | 07:03 PM
Bug_Guy's Avatar
Bug_Guy
You probably already know this, but unless there's an adjustment on the module, the ONLY thing you'll gain by changing your module has to do with the rev limiter, and if you're thinking of running over about 5800 rpms with stock valve springs, etc., DON'T!!
Ignition modules are overrated! They won't give you anymore horsepower, etc. The only thing they do is provide the signal for the spark. The adjustable ones give you some timing ability, but otherwise they only raise the rev limit.
cj_slowdown
Jan 23, 2008 02:36 PM
cj_slowdown
Dec 5, 2007 01:05 PM
jmpancoast
Aug 8, 2007 06:07 PM
bhollis
May 13, 2007 11:13 AM
zaam99
Southwest
Apr 16, 2007 08:04 PM
