Ignition fork lock troubles
Old Mar 31, 2013 | 08:53 PM
Bythebuffalo's Avatar
Bythebuffalo
6th Gear
Default Ignition fork lock troubles
I just bought my 06 Ultra Classic last month. When I was checking it over I noticed that the key they sent with the bike only opened the gas tank, and worked on nothing else. I called the dealer and they sent me a set of new keys from Harley. I try them out and find that they work on everything except the ignition and fork lock. I mean the key turns but the bike doesn't lock down. It seems like there is something in the lock itself that has puked out. I can turn the forks with some effort when its supposedly locked and the ignition on won't lock at all. I probably need a new lockset and am wondering how much it will cost me. I have checked out youtube vids and it looks easy enough to switch them out myself. Any feedback would be welcome.
Thanks
Old Apr 1, 2013 | 07:32 AM
grbrown's Avatar
grbrown
If later bikes are anything like my older one, there is a linkage in that locking mechanism that can get out of adjustment. When you twist the locking **** a lever pushes a small rod into a hole in the top tree and the key locks it in place. Your problem may simply be that it needs attention. It is a pain to get at IMHO and best done with the factory service manual, not only for getting to it, but also for setting it up correctly.
asm481
2014-2024 Touring Models
Aug 3, 2025 10:54 PM
Papa G
May 19, 2015 07:58 PM
captjwteal
Aug 15, 2012 03:43 PM
the_game
Apr 10, 2009 10:32 AM
streetglide13
Feb 10, 2009 05:41 PM
