Speed Wobble
Old May 1, 2013 | 09:30 PM
ny switchback's Avatar
ny switchback
Default Speed Wobble
I need some help I have a Switchback and I get a speed wobble with a cold tire. I was thinking of putting a stabilizer on but wanted to get some thoughts from others on this issue. I bought this bike new and it has never been down. I know its a Harley and not a sport bike but I first noticed this problem when I had a long corner at about 90 after only about five miles on the cold tire. I have not changed anything from last year and it ran prefect last year. It still does but not until the tire warms even then I have gotten it once or twice but it was not to bad. One last thing even going straight about 110 really bad for a sec than goes away as long as you stay in the throttle. Sorry so long but wanted to get as much detail as possible. Thanks for any help I can get.
Old May 6, 2013 | 05:23 PM
grbrown's Avatar
grbrown
The Dyna models have a rubber mount system that leaves a little to be desired! I had an FXDXT for several years and installed a True-Track kit with great success. Even at slow speeds the bike tracked better, held a line more predictably and at speed was just great. I can strongly recommend one.
It is worth commenting that handing problems with rubber mount Harleys doesn't seem to be consistent. If you were to ride a similar bike to yours you could find it either better or worst.
Hope that helps!
Old May 9, 2013 | 07:28 AM
kknickmeyer's Avatar
kknickmeyer
At those speeds just about anything can cause a wobble, windscreens being one. Best investment I've made so far is True Track, I'm almost never over 85-90 mph though. Kurt
Old May 9, 2013 | 07:56 AM
cobaltt's Avatar
cobaltt
slow down!
Old May 9, 2013 | 08:27 AM
ffjflanagan's Avatar
ffjflanagan
Wheel balancing weights maybe ?
Old May 14, 2013 | 10:51 AM
Next In Line's Avatar
Next In Line
If the bike is still under warranty, take it to the dealer and have them look at it.
El Chiguete
May 19, 2015 12:18 AM
Reece64
Jun 22, 2014 11:18 PM
JohnnyRebKY
Jun 7, 2014 09:02 AM
pointblank
May 24, 2011 10:33 AM
Tropicalwarrior
Aug 24, 2010 09:18 PM
