Thundermax Users
Old Aug 25, 2013 | 10:07 AM
Hizenberg's Avatar
Hizenberg
1st Gear
Default Thundermax Users
I only have an apple computer. If i have a base map installed at Zipper's will i be good to go? Or do I still need to hookup to a windows computer?
Old Aug 25, 2013 | 09:23 PM
PFWiz's Avatar
PFWiz
If Zippers loaded the proper map then the TM will work fine out of the box.
Just remember that usually the TM is set to allow 5% max auto tune change without your ok. So in 1000 miles when you should be reading the changes and excepting them (If they look ok) so the TM can be free to further auto tune your bike you will be out of luck. Also if you should for example have some pinging at 4000 rpm at max throttle you will not be able to add some fuel to tune it out...
Old Aug 26, 2013 | 05:35 AM
Hizenberg's Avatar
Hizenberg
1st Gear
Ok, thanks for the info.
davewear
Milwaukee Eight (M8)
Jun 30, 2017 10:49 PM
mpr3369
2014-2024 Touring Models
Mar 24, 2017 06:14 AM
PistolPete83
Jun 4, 2013 03:22 PM
speakerfritz
May 23, 2012 02:08 PM
Craig C.
Mar 12, 2012 07:41 PM
