starter clicks
Old Jun 25, 2014 | 09:04 AM
caclark's Avatar
caclark
Stage I
Default starter clicks
hit the start button and all i got was a click hit it agin and it fired up. got off work went to start and click again this time had to jump the bike off got it fired up then the bike died goin down the road. i had loss of all electronics. any suggestions?
Old Jun 25, 2014 | 09:10 AM
vheflin's Avatar
vheflin
Check for any loose connections. Then fully charge and load test the battery.
Old Jun 25, 2014 | 11:39 AM
nevil's Avatar
nevil
This.
And make sure you check the ground connections. While you're at it, look at the fuses and relays. The tabs must be clean and tight.
You might need a new battery but do the simple stuff first.
londonking
Mar 17, 2024 10:43 AM
LDB187
Feb 21, 2017 06:52 PM
Chris1957
Engine Mechanical Topics
Apr 24, 2016 01:54 AM
martinez_nc
Feb 23, 2013 02:35 PM
Boanerges
Apr 29, 2011 05:10 PM
