Hacked, Conversions and Trailering "Harley Sidecar, Conversion Trikes and Motorcycle Pull Behind Trailering Enthusiasts" A forum for the discussion of your sidecar, Conversion Trike or Pull Behind Motorcycle Trailer.
Need trailer ideas for FLHTK and 3 wheeler
Old Apr 9, 2023 | 11:19 PM
Mark in wi's Avatar
Mark in wi
Default Need trailer ideas for FLHTK and 3 wheeler
First thanks for any ideas/help you can give. I'm looking for ideas on the best way to trailer a HD FLHTK and the wife's Spyder 3 wheeler. I was thinking about something enclosed, but the wife is thinking something open. I haven't trailered bikes often so I could use some suggestions on what has worked for you. Anything like trailer length, tie down systems (good or bad), or anything that can save time and frustration is much appreciated. I have used the search function, but I haven't seen much trailering both a 3-wheeler and a bike.
I do know not to cover on either bike if we get an open trailer! .
Thanks again for any help!
Mark
Old Apr 10, 2023 | 05:41 AM
smitty901's Avatar
smitty901
This place outside Watertown WI. Was great. When I was looking for what would fit my needs. They worked with me to load unload check on different ones that fit my needs. You never really know until you put the bike on the trailer how it will fit.
https://www.tbeequipment.com/
Do you plan to trailer them both at the same time ? What do you plan the pull it with? How often do you plan to trailer ?
If you plan to trailer in Winter ,like get the heck out of Wisconsin. You may want a high ground clearance for snow.
The higher the deck the more issues loading.
All comes in to it.
I do not trailer any of the bikes often but there are times it must be done.
I have my reason for preferring an ope trailer.
Old Apr 10, 2023 | 08:52 PM
Mark in wi's Avatar
Mark in wi
Thanks for the link and response! Mind sharing the reasoning for there open trailer?
Most of the time both will be on the trailer.
Current is Honda Pilot, eventually a pickup/full sized suv.
Currently the thinking is 3-5 trips in summer maybe something in early spring and/or fall. Then in 3-5 years hopefully more trips either on the bikes or using the trailer.
Not sure about winter yet but it is an option we are considering. If we were to use the trailer a lot in winter I'd be mostly looking at enclosed trailers.
All comes in to it.
Old Apr 11, 2023 | 04:47 PM
smitty901's Avatar
smitty901
Flexible for other uses. Better rear view, Lot less drag when empty saves a lot of fuel. Weight. My trailer is 12 feet long and empty weight is only 450 lbs.
Old Apr 18, 2023 | 09:31 AM
jfl330's Avatar
jfl330
Just bought an aluminum slingshot trailer for the exact same purpose. Believe it is 6.5 x 14 with an 8 foot ramp so nice gradual ride on/off. Put spyder in front left corner, bike behind and to the right.
Old Apr 18, 2023 | 10:43 AM
Mark in wi's Avatar
Mark in wi
Would you have any pics you could share? I was thinking/hoping I could get away with a 7x14 and would like to see how much space there is.
Old Apr 18, 2023 | 11:04 AM
jfl330's Avatar
jfl330
This is the trailer: Open Slingshot Trailers (missiontrailers.com)
Have not put on the additional tie downs needed yet, that's next. I have parked both bikes on it to confirm fitment.
DANNER55
Trikes, Hacks and Trailer Parts
Aug 12, 2020 05:47 AM
Alien Spyder
Road Trips
Jun 1, 2013 10:40 AM
VTK
May 23, 2011 02:43 PM
shortride
Touring Parts
Jul 18, 2010 07:52 PM
