No luck on Dyna'so forum....any help here?
The 7k SE Race retards timing 10 degrees. The 6200 SE Performance retards timing 5 degrees.
A common error is installing the 7k module on a bike that actually needs more timing. Your best bet is an aftermarket ignition module that has several curves built in. THen you can dial it for what you have and then re-dial it if you change the motor later.
ddog6900
08-14-2019 08:47 PM
