ECM replacement
Old Aug 31, 2024 | 08:08 AM
Haydo4's Avatar
Haydo4
Default ECM replacement
Hi All,
I have a 2011 Dyna Fatbob that needs a new ECU.
Im after advice as to how and what can it be replaced with.
I don’t want to spend a heap of money on it atm, cos it’s a project bike that I purchased not running, so I’m keen to see if I can make it run first somehow, someway.
The part number for the ecm is 32852-11.
I have an 05 softail, an 07 Sportster and an 07 Ultra classic.
They all have different part numbers on their ECM’s. Are any of them likely to be compatible?
They all have the same size and shape plug as the the 2011 dyna.
Could one be used for testing purposes?
Old Aug 31, 2024 | 11:42 AM
nevil's Avatar
nevil
It's not common for an ECM to go bad, but if that's the diagnosis you don't have much choice. The units that are on your bikes have to be programmed for the Dyna, just like a new blank one that comes from HD. I don't know if any of those are compatible with your bike, so check the part numbers. A dealer can do it, but I've read where someone with the right equipment is able to get that done.
Old Aug 31, 2024 | 12:38 PM
smitty901's Avatar
smitty901
Please provide more information.
Does the bike do anything with batter charged when you turn it on ?
Did it come from a salvage sale ?
All the information can can provide will help others help you.
Old Aug 31, 2024 | 02:50 PM
paulmedford's Avatar
paulmedford
Originally Posted by Haydo4
Hi All,
the 07 will work, just swap it and crank it over but please note the tune would be different and the tssm would shut it down after it starts . But at least you can use it for testing, To use it as a replacement you would have to load the dyna tune after learning the tssm to the ecm. You can bypass the tsm as well
Old Aug 31, 2024 | 02:51 PM
Haydo4's Avatar
Haydo4
Hi Smitty, there is a another thread about the ECM on this site.
please search the below for the full run down of the diagnosis and give me your feedback. Im keen to get it sorted.
2011 Fatbob - No spark on front cylinder
Old Aug 31, 2024 | 06:16 PM
djl's Avatar
djl
Consider replacing with a TMax; kind of pricey but lots of benefits.
AntonyB
Jul 26, 2024 05:36 AM
WillyW
Welcome Area Only
Jul 19, 2024 12:46 PM
cpd2442
Jun 27, 2013 12:26 PM
w8keluv
Jan 23, 2013 03:37 PM
timouus
Sep 2, 2011 02:02 PM
