Can oil be cleaned from SE air filter?
I have a Stage I SE air filter on my '08 Ultra. After a 103" Stage II was installed by a dealer, I noticed smoke coming from the air cleaner after my first ride. I checked the oil level and it was about a half quart overfilled. I syphoned off the extra oil and everything has been OK since then except that each time I got a new flash (dealer download or SERT map), the bike would run well for about a week and then act like it got detuned.A few daysafter the new flash it would lose some throttle response and run like it had a base SERT map, not a dyno tuned map.
The other day I wondered if the air filter was oiled up so I pulled it off and sure enough some oil dripped out. It appeared that the oil had pretty well soaked the bottom part of the filter and wicked its way around the rest of the filter (about 2000 miles on the filter). I cleaned the filter out using Dawn dishwashing liquid and water. I checked the plugs and the tips were the proper color but the base had lots of soft carbon so I replaced them. The bike now seems to run a little better. Here aremy questions: Can washing out a paper SE air filter get the oil out or do I need a new one? (It's hard to tell if the filter is clean since the paper filter has a wire screen cover).
Also, do you think the oily air filter would cause the bike to run rich and lose power?
RE: Can oil be cleaned from SE air filter?
ORIGINAL: TNBagger
