oil from air cleaner?
Old Mar 21, 2006 | 09:12 PM
RichMik's Avatar
RichMik
Default oil from air cleaner?
Has any one experienced this. I have 05 anniv. fat boy, 95inch. The other day after first ride of the season, (about 35 miles) I noticed oil droplets under filter cover. So I removed the filter cover and filter and found oil in the throttle body. I also noticed part of the filter deteriorated. A freind of mine says he has heard some talk of this filter break down.
Any info would be great.
Thanks,
Rich
Old Mar 22, 2006 | 06:34 AM
breaknbad's Avatar
breaknbad
Default RE: oil from air cleaner?
Check oil level.
It is probably a little high. When it is it will get sucked in air filter thru breather.
David
Old Mar 22, 2006 | 09:31 AM
billnourse's Avatar
billnourse
This is a pretty common problem if you have a SE or other high performance air filter on your bike. As said above, insure that you do not have too much oil.
If you are experiencing filter deteriotation I am guessing that you have A SE air filter with the blue rim on it. These have had a problem with coming apart. I think I heard HD was making them good with an updated filter element. You might want to check with the dealer.
K&N is also making a replacement element that is oil treated, and a better filter element that what you currently have.
Hope this helps.
Regards,
Bill
Old Mar 23, 2006 | 09:59 AM
HDF Tech's Avatar
HDF Tech
Here's some info on this problem... https://www.hdforums.com/m_67543/mpa..._/tm.htm#67543
Also one thing that seems to worsen this situation is the single tube vent that crosses over the intake and uses a single vent hose to vent both heads. The later SE units went to twin tubes which pretty much eliminated a lot of oil seeping into the air filter.
azgrumbles
Jun 22, 2017 11:58 PM
AndyinTally
Exhaust System Topics
Mar 26, 2012 09:05 AM
tbell
Dec 11, 2009 11:32 PM
sapperw5
Apr 8, 2007 10:22 PM
uniondog1
Feb 12, 2007 04:55 PM
