06 RK 25 degree INJECTOR ?
Just picked up my FLHRI today from dealers,after having 25 degree injectors installed.
Dealer said that an upgrade to the computer wasn't needed,and that the job was a
straight swap, 8 degree to the 25 injectors. He said a bike with SE mods would require
an upgrade,but that a pure stock bike,which mine is, didn't need it.
Is he right about this? Seems strange to me, but this is the first injected bike I've owned.
RE: 06 RK 25 degree INJECTOR ?
ORIGINAL: Roadie 49
Your dealer is correct. With no other mods the injectors should just get rid of some of the lean running conditions and help with starting as stated above. When you decide to put on a better air cleaner and some pipes it will make it easier to tune with whatever system you decide to go with (PCIII or SERT).
hdjoe88
21
01-06-2007 01:38 PM
bensonjv
12-24-2006 01:17 AM
