Overheating headlight???
Old 04-02-2006, 12:00 AM
XL883R's Avatar
XL883R
XL883R is offline
Stage III
Default Overheating headlight???
Need some help with a very hot headlight.
I have recently completed a 883 to 1200 conversion and as part of the project I added a single-fire ignition and coil, HD tachometer kit, and replaced the standard dash indicator light strip with much better looking individual bulbs. All of the wiring went smoothly and everything is working just fine. The problem I am having is that the headlight now gets VERY hot within a minute or two of turning on the ignition. The bulb always generated some heat but I don't ever remember it getting this hot. The headlight wires were not involved in any of the new work I did.
Any suggestions? Could this be a ground issue?
Thanks!
Old 04-02-2006, 02:13 PM
tripl8's Avatar
tripl8
tripl8 is offline
Default RE: Overheating headlight???
Pur an Amprobe on the leg and see what kinda amps its drawing ...strange occurance indeed.
Old 04-02-2006, 02:51 PM
Rhubarb's Avatar
Rhubarb
Rhubarb is offline
Maybe something damaged your voltage regulator and its allowing too much voltage through your system?
Usually if a headlight bulb is too hot, it will burn out pretty fast. Maybe you just remember it being cooler?
Old 04-02-2006, 03:10 PM
tripl8's Avatar
tripl8
tripl8 is offline
In that case..he needs to make sure the battery,s not getting more than 14.7 VDC at peak..
Old 04-04-2006, 12:30 AM
XL883R's Avatar
XL883R
XL883R is offline
Stage III
Thanks, all for the suggestions.
After quadruple checking all of my wiring I concluded that I did not have a problem and the headlight must have always run that warm and I just didn't notice (how often do you touch your headlight anyway?). A few minutes later a fellow Sporty rider came over for a beer and the headlight on his unmodified bike was just as hot as mine after only a 10 mile ride.
Maybe the Motor Co. just didn't want to leave us stranded at a rally campground without a way to fry an egg for breakfast!!!
Old 04-04-2006, 12:32 AM
tripl8's Avatar
tripl8
tripl8 is offline
The MOCO always watches out for your best interest....you know that!!
Jreed1976ironhead
Ironhead
06-13-2018 06:48 PM
homer713
10-03-2015 09:39 PM
nathanw
Electrical/Lighting/Alarm
07-06-2012 08:05 AM
okennon1
09-24-2008 07:48 PM
Boogity_Boy
04-16-2006 03:58 PM
Quick Reply: Overheating headlight???
