Sert tuning - closed loop bias tables
Old 01-23-2009, 05:24 PM
shepo's Avatar
shepo
shepo is offline
Default Sert tuning - closed loop bias tables
Hi,
Does changing the voltage readings in the SERT Closed-Loop Bias Tables to increase / decrease the AFR cause the ECM to believe it is still running at 14.6 (and thus staying in closed loop mode) but in fact it is actually running richer or leaner?
Also, does anybody know if it is possible to save the original factory supplied base program map supplied on the ECM prior to installing other factory maps?
cheers,
shep.
Old 01-23-2009, 06:06 PM
HERKO's Avatar
HERKO
HERKO is offline
"Does changing the voltage readings in the SERT Closed-Loop Bias Tables to increase / decrease the AFR cause the ECM to believe it is still running at 14.6 (and thus staying in closed loop mode) but in fact it is actually running richer or leaner?"
Yes for the most part. See pgs 11 & 17 of SEST Manual or pg 3 of SERT manual for more info.
"Also, does anybody know if it is possible to save the original factory supplied base program map supplied on the ECM prior to installing other factory maps?"
No, not available with SERT or SEST. This requires a TTS Master Tuner.
Old 01-24-2009, 12:41 AM
shepo's Avatar
shepo
shepo is offline
Hi, thanks very much for your reply.
I did see that in the SERT manual but I was just not sure whether by changing the switching voltage of the O2 sensor 'actually deceives' the ECM of the true reading / situation. On a second reading of the manual it would appear it does and it is a way of enriching the AFR whilst staying in Closed-Loop Operation as per the map.
cheers, shep.
ButtMan1000
10-28-2008 11:16 AM
supernova
04-27-2008 05:31 PM
cjike
07-03-2007 07:34 PM
clayman
07-23-2006 01:07 AM
arachman
07-23-2006 12:11 AM
Quick Reply: Sert tuning - closed loop bias tables
