Trouble code HELP!
Old Mar 21, 2010 | 10:47 AM
Hoshbosh's Avatar
Hoshbosh
Default Trouble code HELP!
I have an '05 VRSCB. Recently installed a fuel moto EFI tuner and a rinehart 2-1 full system. For some reason, when i turn the key on and wait about 3 seconds all the flashers blink about 5 times and shut off. Then when i start the bike they red key on the dash is lit up which i beleive means there is a code in it. Also when i turn a signal on, it blinks normal for a few seconds and then blinks flash for the remainder of time that it is on. Anyone have any ideas on this? Is there any way to figure out trouble coats without taking it to the dealership? I am just curious if the code and the flasher issues are related?! Any help would be great!
Thanks in advance!
Hoshbosh
Old Mar 21, 2010 | 01:11 PM
nocarb's Avatar
nocarb
Thanks in advance!
Hoshbosh
I'm not sure about the flashers flashing 5 times. To my knowledge, the red key staying lit does not mean you have a code. Maybe a security code? It sounds like you need to reset your turn signal module. I'm not sure if I remember how to do this but I think you turn one turn signal on and let it flash five timew and then go directly to the other and let it flash five times. Something like that anyway. It explains it in the electrical service manual.
The other thing you may want to try is removing the tuner and see if it still does it. May want to talk to Jamie at Fuel Moto.
Old Mar 21, 2010 | 09:13 PM
Hoshbosh's Avatar
Hoshbosh
Do you think it has somthing to do with the tuner? I cant see how that would affect anything but then again ya never know i guess. I tried to reset the module like you said and had no luck. but that is the correct way.
I read a forum on here and figured out how to get into the diagnostic system on my bike. So i have a couple codes but do not have the sheet to decode them. Anyone know where i can get this? I did clear the codes and everythign went somewhat normal until the next time i cycled the key! I also realized that my brake light decides not to work now! I am thinking it may be related!
Old Mar 21, 2010 | 09:18 PM
SBJJC's Avatar
SBJJC
Thanks in advance!
Hoshbosh
Had this happen to me, right before my fob battery went dead. Then when the bike didn't start, I freaked out, had it towed to the dealership. They laughed gave me a battery for free (since I paid 65 bucks to tow it). They asked me if the flashers and red key light came on a few days ago. I was amazed, like they were god… how could they know these things… well I felt like a fool later when I found out…
Take your fob to Wal-Mart and get a 2 dollar watch battery. Don't take it to the dealer and pay 7 bucks for the same battery
Old Mar 21, 2010 | 09:22 PM
SBJJC's Avatar
SBJJC
Here are a few codes to help though:
Be advised this only applies to the full serial data bikes, ie 04 and 05's
The IM (instrument module) is capable of displaying DTC's (diagnostic trouble codes).
Speedometer Self Diagnostics: The speedometer is capable of displaying and clearing speedometer, tachometer, TSM/TSSM and ICM/ECM Diagnostic Trouble Codes (DTC).
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range
and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word ìdiagî should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module)
to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module (EFI) / (Ignition Control Module, 'Carbureted')
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
6 - To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTCís the code will be
displayed or the word ìnoneî will appear if there are no DTCís. Push the odometer reset button again to view additional codes if they exist.
7 - Record the codes.
8 - If DTCís are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up.
Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTCís again by repeating steps 1 to 9.
If the code is current it will reappear.
9 ñ Press and release the odometer reset button to continue to the next module.
10 ñ Turn Ignition switch to OFF.
DTC FAULT CONDITION MODULE
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
AFR ñ Air Fuel Ratio
ATS ñ Air Temperature Sensor
BAS ñ Bank Angle Sensor
CCM ñ Cruise Control Module
CKP ñ Crank Position Sensor. The CKP generates an ìAC signalî which is sent to the ECM where it is used to reference engine position (TDC) and speed.
DTC ñ Diagnostic Trouble Codes
ECM ñ Electronic Control Module. (The Computer) Computes the spark advance for proper ignition timing and fuel control based on sensor inputs
(from CKP, MAP & TP sensors) and controls the low-voltage circuits for the ignition coils and injectors.
The dwell time for the ignition coil is also calculated in the microprocessor and is dependent upon battery voltage. The programmed dwell feature gives adequate spark at all speeds.
ECT ñ Engine Coolant Temperature. Sensor also controls the cooling fan relay that provides 12 Vdc to the fans.
EFI ñ Electronic Fuel Injection
EFP ñ Electronic Fuel Pump
ET ñ Engine Temperature sensor
FI ñ Fuel Injectors
FPR ñ Fuel Pressure regulator
IAC ñ Idle Air Control actuator
IAT ñ Intake Air Temperature sensor
ISS ñ Ion Sensing SystemÖdetonation detection
MAP ñ manifold Absolute Pressure sensor. The MAP sensor monitors the intake manifold pressure (vacuum) and sends the information to the ECM.
The EMC then adjusts the spark and fuel-timing advance curves for optimum performance.
TP ñ Throttle Position Sensor
VE ñ Volume Efficiency
VSS ñ Vehicle Speed Sensor. Used as an input for idle speed control
Old Mar 21, 2010 | 09:23 PM
SBJJC's Avatar
SBJJC
Hopes this helps
Cheers
Old Mar 23, 2010 | 07:37 AM
Hoshbosh's Avatar
Hoshbosh
well i fixed it. I guess you cannot have LED turn signal bulbs in all four signals without a load equalizer. Thanks for the input!
tuneman59
Apr 25, 2017 07:32 PM
Bodean46
Dec 10, 2014 11:00 PM
Sailrider 1
VRSC Models
Oct 8, 2014 06:32 PM
AA79912
Feb 13, 2013 08:42 AM
Hoshbosh
Electrical/Lighting/Alarm
Mar 21, 2010 10:49 AM
