replacing off/run start buttons
hopefully someone can help me. i'm swapping my bars this weekend, hopefully if the parts come in, and i'm going with a hidden switch bar from exile. it has 4 switches for blinkers, brights and horn. i want to replace and relocate my off/run start buttons with toggle switches that i can hide somewhere on the bike.
i just took my old switch casing apart and the off/run has 2 wires running to it, grey and white, the white wire jumps to the start button and a black wire exits the start button, ground i guess. i don't know a lot about wiring but can i just run 2 toggle switches, one momentary switch and one regular toggle or is it more complicated than that? or is there a 3 position toggle, off/run/momentary that i can use?
if you're going to answer, can you use small words, i'm not that bright and i've never screwed with wiring before. thank you.
