cleaning up bars - help with start button
Old Feb 9, 2012 | 10:26 AM
ddellostritto's Avatar
ddellostritto
Default cleaning up bars - help with start button
i know it's been discussed over and over, but i still haven't found the right information i'm looking for. i'm currently in the process of cleaning up my bars on a 2007 dyna street bob. so far i've attached a toggle switch to the light bucket to control my head light. i've taken away both turn signals and the horn. the new throttle housing is on its way, but in the mean time i'm having a hell of time with the new starter button. the original set up had a black and white wire come from the start button and a gray and white wire come from the kill switch, with the white wires connecting to each other. my question is, what is the proper way to wire the new momentary start button? any help would be greatly appreciated. thanks.
Old Feb 9, 2012 | 04:45 PM
Robbie13's Avatar
Robbie13
LOSER
What kind of switch/button are you putting on? If it is a switch your old kill switch wires should go to your new on/off contacts of your new switch then the start button wires to your momentary contacts of the new switch.
Old Feb 10, 2012 | 08:31 AM
ddellostritto
it's a universal start button picked up at O'Reilly Auto Parts
Old Feb 10, 2012 | 05:29 PM
Robbie13's Avatar
Robbie13
LOSER
Ok. What are you trying to delete?
Old Feb 13, 2012 | 02:11 PM
ddellostritto
the turn signals have been long gone. the horn is non exsistent. i'm going to a jockey shift. all i'm looking to run is just the front brake and throttle.
Old Feb 13, 2012 | 05:58 PM
Robbie13's Avatar
Robbie13
LOSER
You will still need some kind of on/off switch.
Old Feb 13, 2012 | 06:10 PM
TRacer's Avatar
TRacer
Remove the stock RUN/OFF switch, tape it into the "Run" position and tuck it under the tank, or, as an alternative, remove the RUN/OFF switch and solder the two wires together. Move the factory starter switch and tuck it under the tank as well. Take that O'Reilly's thing back and get one of these:
You can get them here:
http://www.ebay.com/sch/i.html?_nkw=...starter+button
You will still be able to have ignition key control; the only difference is that the direct plunger button will kick the starter over for you, bypassing the relay. You might have to reach around a pipe to get to it like I do (I push it in with my thumb), but I like the stealth and anti-theft factor.
Old Feb 15, 2012 | 07:56 AM
ddellostritto
the solenoid push button is installed
the gray and white run/off wires are wired up to each other
i press the start button and it cranks
not starting though
help
Old Feb 18, 2012 | 11:56 AM
TRacer's Avatar
TRacer
not starting though
help
Did you turn the key on? You will still need to do that.
ShaneO926
Electrical/Lighting/Alarm
Jun 26, 2016 10:30 AM
ODBuffalo
EVO
Aug 5, 2013 03:32 PM
gscully
EVO
Nov 8, 2010 05:50 AM
laythss
Oct 20, 2010 03:50 PM
chinexican
Jul 15, 2009 03:30 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
