Power Vision Information Thread
Old 02-19-2024, 07:10 AM
BrandonSmith's Avatar
BrandonSmith
BrandonSmith is offline
Received 2,238 Likes on 1,418 Posts
I started my own thread for better visibility: Spark Timing Adjustments Based on Data Logs - Harley Davidson Forums (hdforums.com)
Originally Posted by BrandonSmith
I'm new to tuning. I have a PV2 from @fuelmoto with their canned tune. I have run multiple Auto Tune sessions. Now I'm looking at timing. I know I can reach out to FM to get the timing dialed based on my logs. However, I like to learn and have an understanding of what is going on. I have the time to look at it myself and want to get some hands-on experience tweaking a tune.
I plotted my spark knock retard events from my data logs. Below is RPM vs MAP (kPa) x Spark Knock Retard Front Cylinder (degrees). The plot contains over 15,000 data points from my log of over 30,000 data points (i.e., over half of my data points contain knock retardation).
Based on this info, from 50-85 kPa and 2000-3500 RPM, I am getting between 2-3 degrees of knock retardation. Therefore, should I retard my timing in that region by the corresponding degrees of knock retard (i.e., the advance timing number would be smaller)?
Am I thinking about this correctly? Or should I just leave it alone and let the ECU sort it out?
E10 91 octane. This graph gets off the charts (6+ degrees) on non-ethanol 87 (the only non-ethanol in my city).
Rollbar (02-19-2024)
  #9602
Old 02-21-2024, 06:58 AM
BrandonSmith
Can anyone explain what "Adaptive" means on the Config1 page of Quick Tune?
Is it spark?
Is it fuel?
  #9603
Old 02-21-2024, 08:18 AM
rigidthumper's Avatar
rigidthumper
rigidthumper is offline
Received 5,472 Likes on 1,604 Posts
Adaptive fuel (long term fuel trims, based on short term fuel trims).
BrandonSmith (02-21-2024)
87gtNOS
13
08-03-2023 07:04 AM
Glock Enthusiast
08-29-2011 07:00 PM
Rickr01
08-10-2011 01:40 PM
Cheiron
08-20-2010 11:05 AM
roadkinglobo
01-07-2010 09:21 AM
Quick Reply: Power Vision Information Thread
