Old Mar 17, 2015, 12:05 PM
How-Tos on this Topic
Last edit by: IB Advertising
Harley Diagnostic Codes
http://www.hdforums.com/forum/igniti...tic-codes.html
Issue:
Road King is having issues and user has trouble finding diagnostic codes, so he decides to put together a list of common codes that are not easily findable.
Read below for full discussion…
Print Wikipost
Old Mar 8, 2021 | 09:24 PM
  #121
Zanthamos's Avatar
Zanthamos
Deleted
Old Mar 8, 2021 | 10:45 PM
  #122
Dkraut's Avatar
Dkraut
4th Gear
Gonna have to bite the bullet and bring it in to the dealer....
Old Feb 15, 2022 | 02:05 AM
  #123
FlamingHooligan's Avatar
FlamingHooligan
6th Gear
Just a quick question gents. I intermittently get code P1353 (no combustion front cylinder) and recently have been getting a P0131(Front 02 sensor lean), Neither illuminate the check engine light and when cleared don't return for several rides. Also, the performance of the bike is flawless so can't figure out what might be happening. Any thoughts would be very helpful.
It is a 2010 Road King Classic with the 103.
Old Feb 15, 2022 | 01:12 PM
  #124
Old Sport's Avatar
Old Sport
Fuel delivery / injector issue?
I had an intermittent P0131 for a while last year... With my PV, I was able to see my AFR reading maxed for periods of time. I swapped the sensor thinking it went bad but the issue remained. It cleared on it's own before I got a chance to pull the fuel injector. I assume the injector was clogged for a period of time then cleared.
Been good for a while now (replacement injectors on the shelf at the ready!).
Old Feb 15, 2022 | 11:18 PM
  #125
FlamingHooligan
6th Gear
Thanks for the Reply Old Sport!
It may very well be, but wouldn't a failing injector exhibit rough running at some point while in operation? I mentioned that the bike has been running flawlessly and there would have been no reason to suspect that there was a problem if I hadn't checked the codes after each ride as I do. I then record them and clear them.
While on that point, Can someone school me about having codes turn up without the check engine light illuminating, I have been told that indicates "Historic", is this the truth or is there more to it than that. I would assume that if a code was historic once it has been cleared that would be the end of it and if it did return it would be current and illuminate the check engine light?
definitely got me puzzled!
Old Feb 16, 2022 | 08:27 AM
  #126
Old Sport's Avatar
Old Sport
It may very well be, but wouldn't a failing injector exhibit rough running at some point while in operation?...
Yep, I agree... Just sharing my experience.
Old Feb 18, 2022 | 05:37 AM
  #127
Tomhd13's Avatar
Tomhd13
Stage II
Default Dyna Trottle Response
Originally Posted by skos
My Road King had some sputtering issues and I had some codes
I could not find any info on codes here but saw a lot of people asking about them and have had no replies. My piece of crap dealership service manual does not have them so I did some research and came up with the following.
Can someone double check me to make sure this is correct?
To access codes
1- Turn Ignition switch to OFF & Run/Stop switch is to Run.
2- Push odometer reset button in & hold.
3- Turn ignition switch to Ignition and release odometer reset button. Background lighting sould illuminate, speedometer needle should sweep its full range and indicator lamps (battery, security, low fuel, check engine and cruise) should illuminate. The word “diag” should then appear.
4 - Push the odometer reset button once and you will see the selection menu "PSSPt" (on mine the “t” looks more like a “╘” )with the first P flashing.
5 - Each letter represents an area of the diagnostics module. The module that is flashing is the one you are going to check. To move from one letter (module) to the next, you push the odometer reset button one time. (from P to S to SP to t and back to P, etc.)
P = ECM/ICM (Electronic Control Module [EFI] / Ignition Control Module [Carbureted])
S = TSM/TSSM (Turn Signal/ Turn Signal Security Module)
SP = speedometer
T = tachometer
To get the DTC within an area of diagnostics, push and hold the odometer reset button in for 5 seconds and release. If there are any DTC’s the code will be displayed or the word “none” will appear if there are no DTC’s. Push the odometer reset button again to view additional codes if they exist.
1 - Record the codes.
2 - If DTC’s are not to be cleared, Press and release the odometer reset button. Part number of module will be displayed.
NOTE: To determine if a code is current or historic, clear the displayed code by pushing in and holding the odometer reset button ( longer than 5 seconds) until 'clear' comes up. Release the odometer reset button. Turn OFF the ignition switch. Run your bike and shut it down then recheck the DTC’s again by repeating steps 1 to 3 If the code is current it will reappear.
4 – Press and release the odometer reset button to continue to the next module.
5 – Turn Ignition switch to OFF.
On models not equipped with a tachometer "No Rsp" will appear when the tachometer identifier is selected.
"No Rsp" will also appear if the run/off switch is in the off position when doing this procedure.
HFSM = Hands Free Security Module
TSM = Turn signal module
Priority/DTC/Fault condition
1. P0605 ECM FLASH Memory Error
2. P0603 ECM EEPROM Memory Error
3. U1300 ECM Serial Data Low
4. U1301 ECM Serial Data High
5. U1097 Loss of Speedometer Serial Data to ECM
6. U1064 Loss of TSM/FSFM Serial Data to ECM
7. P1003 System relay contacts open
8. P1002 System Relay Coil High/Shorted
9. P1001 System Relay Coil Open/Low
10. P1004 System Relay Contacts Closed
11. P1009 Incorrect Password
12. P1010 Missing Password
13. P06415 V+Vref 1 Out Of Range
14. P06515 V+Vref 2 Out Of Range
15. P0373 CKP Sensor Intermittent
16. P0107 Map Sensor Open/Low
17. P0108 Map Sensor High
18. P0374 CKP Sensor Synch Error
19. P1600 EFI Module Processor Internal Error
20. P1270 TGS Validation Error
21. P2107 EFI Module Processor Internal Fault
22. P2122 TGS1 Low/Open
23. P2123 TGS1 High
24. P2127 TGS2 Low/Open
25. P2128 TGS2 High
26. P2138 TGS Correlation Error (Twist grip sensor)
27. P0120 TPS1 Range Error
28. P0220 TPS2 Range Error
29. P0122 TPS1 Low
30. P0123 TPS2 High/Open
31. P0222 TPS2 Low
32. P0223 TPS2 High/Open
33. P2135 TPS Correlation Error
34. P2119 EFI Motor Throttle Body Range Performance
35. P2100 EFI Motor Circuit Open
36. P2101 EFI Motor Circuit Range Performance (Actuation Error)
37. P2102 EFI Motor Circuit Low
38. P2103 EFI Motor Circuit High
39. P2176 EFI Closed Position Not Learned
40. P1514 Air Flow Fault
41. P2105 EFI Forced engine shutdown
42. P1501 Jiffy Stand Sensor Low
43. P1502 Jiffy Stand Sensor High
44. P0572 Brake Switch Low
45. P0117 ET Sensor Low
46. P0118 ET Sensor High
47. P0112I AT Voltage Low
48. P0113I AT Voltage Open/High
49. P1351 Front Ignition Coil Driver Open/Low
50. P1354 Rear Ignition Coil Driver Open/Low
51. P1352 Front Ignition Coil Driver High/Shorted
52. P1355 Rear Ignition Coil Driver High/Shorted
53. P1357 Front Cylinder Combustion Intermittent
54. P1358 Rear Cylinder Combustion Intermittent
55. P0261 Front Injector Open/Low
56. P0263 Rear Injector Open/Low
57. P0262 Front Injector High
58. P0264 Rear Injector High
59. P0562 Battery Voltage Low
60. P0563 Battery Voltage High
61. P0501 VSS Sensor Low
62. P0502 VSS Sensor High/Open..
63. P1356 Rear Cylinder No Combustion
64. P1353 Front Cylnder No Combustion
65. P0444 Purge Solenoid Open/Low
66. P0445 Purge Solenoid High
67. P1475 Exhaust Actuation Position Error
68. P1477 Exhaust Actuator Open/Low
69. P1478 Exhaust Actuator Shorted/High
70. P0131 Front Oxygen Sensor Low
71. P0151 Rear Oxygen Sensor Low
72. P0132 Front Oxygen Sensor High
73. P0152 Rear Oxygen Sensor High
74. P0134 Front Oxygen Sensor Inactive
75. P0154 Rear Oxygen Sensor Inactive
76. P1510 EFI Limited Performance Mode
77. P1511 EFI Power Management Mode
78. P1512 EFI Forced Idle Mode
79. P0577 Cruise Control Input High
1. U1300 Serial Data Low
2. U1301 Serial Data High
3. U1016 Loss of ECM Serial Data
4. U1255 Serial Data Error
5. B1142 Smart Security System Internal Fault
6. B1135 Accelerometer Failed
7. B1136(HFSM) Accelerometer Tip Test Error
8. B1151 Bank Angle Sensor(BAS) Short to Ground
9. B1152 Bank Angle Sensor(BAS) Short to Battery
10. B1153 Bank Angle Sensor(BAS) High
11. B1154 Clutch Switch Input Short to Ground
12. B1155 Neutral Switch Input Short to Battery
13. B1134 Starter Output High
14. B1121(TSM) Left Turn Output Fault
B1121(HFSM) Left Turn Output Open
15. B1122(TSM) Right Turn Output Fault
B1122(HFSM) Right Turn Output Open
16. B1123(HFSM) Left Turn Output Short to Ground
17. B1124(HFSM) Right Turn Output Short to Ground
18. B1125(HFSM) Left Turn Output Short to Battery
19. B1126(HFSM) Right Turn Output Short to Battery
20. B1143(HFSM) Security Antenna Short to Ground
21. B1144(HFSM) Security Antenna Short to Battery
22. B1145(HFSM) Security Antenna Open
23. B0563 Battery Voltage High
24. B1131(HFSM) Alarm Output Low
25. B1132(HFSM) Alarm Output High
26. B1141(TSM) Ignition Switch Low/Open..
B1141(HFSM) Ignition Switch Low/Open
does anybody know how to adjust the TR on a pro street tuner I did the stage one tune and it still feels a bit sluggish
Old Mar 17, 2022 | 08:21 PM
  #128
Trent Smith's Avatar
Trent Smith
Default P0463
Just recently had a big bore installed. Got the bike back and have a fuel level sending error. I can’t get it to clear. Fuel level travels up and down shows full or empty. And everything diagnostically checks out. Any suggestions
Old Oct 20, 2022 | 09:14 AM
  #129
mike705's Avatar
mike705
Stage I
Default Same readings. Help
Originally Posted by Corsair
The original poster said there is nothing wrong......
"After all the diagnostic codes are displayed, the speedometer's pulses per unit (PPU) setting is displayed. This number will vary depending on speedometer part number.
SPEEDOMETER TROUBLE CODES
CODE - TROUBLE - WIRE COLOR
d01 - speed sensor power output shorted low - red
d02 - speed sensor power output shorted high - red
d03 - not used
d04 - not used
d05 - speed sensor return shorted high - white
d06 - speed sensor return shorted low - white
d07 - not used
d08 - peedometer power overvoltage - orange/white
d09 - speed output shorted high - white/green
d10 - speed output shorted low or open - white/green
5 digit number - speedometer pulses per unit"
also "CLR means clear.
Again, not my answer, copied from elsewhere a while back as a reference.
did you ever find out how come it reads these settings and not the troubleshooting code. I only have a check engine light on and flashing code 33 but is a carburetor bike and that is a injector code. Mine is a 2003 heritage softail classic
Old Nov 26, 2022 | 01:33 PM
  #130
Bighen91's Avatar
Bighen91
Stage II
Default 2013-street glide
Long story short. Buddy has a 2013 street glide. We swapped the bars out, did about 350 mile ride, had no issues at all. We went on a ride 3 weeks later. We got to the stop light, we go to take off and he lost throttle and went into limp mode. We pulled the codes and got p2107 and p1511. Did some research and followed the steps. We replaced the TGS first, the bike rode good for a week, then same issue came back. Next step was to re-pin the throttle body, we did so and same issue instantly came back, finally we replaced the entire throttle body with an OEM from HD. The bike gave some issues at first meaning it was losing throttle and going into limp mode the first 15 minutes. Finally the bike was riding good, rode for about 30 mile or so and then bam, same issue again lost throttle. Pulled the code and again p1511 and p2107, but not also throwing code p0261, p0263, and p1655. Any body have any guidance on this? All help is appreciated thanks.
Gar596
Jul 23, 2020 11:41 AM
SevieC
Oct 25, 2012 07:04 PM
wayne schwedler
Oct 24, 2012 04:50 PM
FiremanJeff
Oct 19, 2012 09:52 AM
gunner11
Nov 9, 2010 02:20 PM
