FP3 Throttle Progressivity change fail
Old Nov 28, 2022 | 12:27 PM
lazybee's Avatar
lazybee
Default FP3 Throttle Progressivity change fail
I changed my throttle progressivity from stand plus to moderate. I've change before without issue, but on this time the bike will not start. Acts like the run/stop switch is on. Radio and lights work, but nothing when I hit the start button. Battery showing 12 volts. I flashed back to stock map. Still nothing. Called V&H. First thing he said was charge battery. I had already checked battery connections and voltage. Tells me to change to stock map. Told him I already had. I read off the trouble codes and he said I should take to dealer. I thought they had a way to access the ecm to see if it was the problem, but he says no. Error codes are
P0072, P0108,P0112,P0113,P0118,P0120,P0123,P0691,P1356, P01353,P1510,P2105,P2123,P2138,U0100(lost communication with ecm). Any ideas appreciated. Thanks.
Old Nov 28, 2022 | 12:33 PM
CoolBreeze3646's Avatar
CoolBreeze3646
Error codes can be found here: https://www.hdforums.com/forum/gener...clude-abs.html
Or here:https://www.fuelmotousa.com/p-29661-...ble-codes.html
Stating the year and model of your bike might help.
How old is your battery, 12VDC is basically a dead battery should read at least 12.3 - 12.5, best if around 12.8 VDC resting.
Old Nov 28, 2022 | 12:38 PM
lazybee's Avatar
lazybee
Sorry, 2014 Ultra Classic.
Old Nov 28, 2022 | 12:47 PM
CoolBreeze3646
Get the battery load tested. A battery can have 12 volts but not enough amperage to start the bike.
Easy things first, then move on to more difficult trouble shooting.
Old Nov 28, 2022 | 12:59 PM
lazybee's Avatar
lazybee
Thanks for response. I will have it tested.
Old Nov 28, 2022 | 03:32 PM
lazybee's Avatar
lazybee
Battery less than a year old tested good.
