need ECM help
Old Aug 30, 2011 | 05:34 PM
harleyflynlow's Avatar
harleyflynlow
1st Gear
Default need ECM help
ok month or so ago I took my 98 electraglide into a dealer to get my bike on the dyno because I put new pipes on rode the bike there ran real good so a few days I go get it it runs like crap they tell me the cold idle might have to be ajusted the would make me a good deal.... they would get me in later. couple days later the bike will not start..the 5 amp fuse to the ECM is blown change it nothing a week later (out of town) I go out and it will start but only one cylender now .... I think that the ECM went south on me. I can get one new in the box p/n 32423-97 mine is 32423-97b what are the upgrades from the 97.97b.97c and will it have to be dynoed again or would the power commander hold that info ?
Old Aug 30, 2011 | 07:36 PM
Trucky911's Avatar
Trucky911
Did you try disconnecting the power comander to see if your bike runs better?....And welcome to the forum....
Trucky911
Old Aug 30, 2011 | 07:52 PM
ajayrk's Avatar
ajayrk
The power commander will keep its map. What series PC is it?
Are you saying that after the dyno tune the bike ran worse?
Do you have the software for the Power Commander? If so hook it up and retrieve the map.
A faulty head temperature sensor will cause running problems.
Old Aug 30, 2011 | 08:58 PM
harleyflynlow
1st Gear
the power commander is series 3 think around 6 years old I bought the bike 4 years ago with the pc on it so no software. and ya when I picked the bike up at ALEFS HD in wichita ks the bike would not start then we got it to start but ran like crap rode it home about 30 miles and parked it I tryed to start it a week or so later it would not start went out a week later finaly got it started but sounds like only one cylender it pops cracks then dies... I dont know what they did but they are a waste of time
Old Aug 31, 2011 | 07:22 AM
TickTock's Avatar
TickTock
For trouble-shooting the best advice given so far was to remove the power commander to see if the bike runs better. More than likely you have a defective power commander not a defective ECM. If the bike runs on both cylinders and sounds basically ok, then the next step would be to replace the power commander with a proper map for your set up. You can download software from the dynojet website and reload the map on your current PC as well to see if that helps. Before you put a new map in, make sure you use the power commander software to save the one that is currently in it. Reading the PC manual will help greatly.
Old Aug 31, 2011 | 02:45 PM
harleyflynlow
1st Gear
ok you guys just saved me alot of money.....it was the power commander not the ecm...less money for sure. again thank you.
Old Aug 31, 2011 | 03:58 PM
ajayrk's Avatar
ajayrk
Old Aug 31, 2011 | 08:10 PM
harleyflynlow
1st Gear
I called dynojet (power commander) today to get the things to download my pc and the tech told me to just send it to them they would fix my pc for 30 bucks or sell me a new one for 200 and they would download the info on the new one....wow.... I had to go dig it out of the trash
Old Sep 1, 2011 | 10:16 AM
JustDennis's Avatar
JustDennis
DynoJet is very good to work with. Good luck and glad you found the issue.
HERE
Feb 29, 2012 11:12 PM
stonesmith
Sep 4, 2011 07:31 PM
MrHog
Aug 25, 2009 07:18 PM
ToadsUltra07
Sep 2, 2008 08:43 PM
Soft06
Jan 29, 2007 10:41 PM
