map question
map question
What is a more important criteria to follow when picking out the closest map to your exhaust set up?
For example if I have a 2 into 1 with no close match, but find a 2 into 2 exhaust with the same exact headers I'm running, will that map run good? Or am I still better off using a 2 into 1 map even though though is no close match?
I've heard people tell me that the headers were the most important, but others tell me the the over length vs 2-1/2-2....
The engine is stock w/ stage 1 air cleaner.
There is no but lakester 2 into 1 on dynojet's site, but there is a bub lakester 2 into 2. So I can either use that or use another 2 into 1 map w/ a different exhaust.
