No spark, plugs dry
No spark, plugs dry
I bought an 2002 Ultra Classic with some front fender and outer fairing damage. Was told it rear ended a pickup. Not much damage, all gages and lights work. The problem isit will not start or even fire.It has no spark and don'tthink its getting fuel (plugs are dry) the fuel pump cycleson. Being the bike was in a crash is there any kind of inertiaswitch that could be tripped and can it be reset? Or is there something else I should be looking at?
RE: No spark, plugs dry
If you are not getting a crank signal, you will not getan ignition spark or a fuel injector pulse. Check for damage by your oil filter where the crank sensor is located, sometimes they get damaged just changing afilter.
When cranking, does your tach move to around 200-300 RPM? If it does your crank sensor isprobably OK.
Rockabill
04-20-2015 06:54 AM
