PC III - Stock or Screaming Eagle A/C
I own a 2007 Street Glide.
I'm going for a PC III Usb and Vance & Hines oval slip-ons.
At Dynojet web there are 2 maps for 07 tourings with this mufflers:
- Stock A/C
- Screaming Eagle A/C
I think I'm staying with stock A/C for a while, do you see any problems???Doing that, I'll save some money. And in a few months maybe I will upgrade.
Besides, both maps seem to be very similar, being SE a little richer, obviously...
- Stock A/C
RE: PC III - Stock or Screaming Eagle A/C
To the contrary, the pipes and PC III will work ok but definitely not ideal. The air cleaner with just the PC III is a much worse scenario. IMO I would put all three on at the same time. The pipes can't give you the performance advantage without the air cleaner. The air cleaner can't give you the advantage without the pipes. You open the exhaust, you open the intake...create flow.
hippharley
01-26-2007 12:50 AM
