Problem with sportster
RE: Problem with sportster
hey, this may help, check to see that the cable did not melt where it runs close to the cylinder . If that did not happen take the carb off the manifold and un-screw the black nut. it may have gotten "gummed up" with varnish.
P.S. I would not lube the choke cable as it works on friction and if you do get it freed-up it will never hold position again. I hope this helps!!!!!
