TTS MasterTune Accel Enrichment Table ??
Old 09-11-2014, 06:54 PM
Fritzables's Avatar
Fritzables
Fritzables is offline
Default TTS MasterTune Accel Enrichment Table ??
I would like to better understand how the Accel Enrichment Table functions in the TTS MasterTune Calibration files.
In the comments for the AE, it suggests that the value in this table is a multiplier and is used against the Base Injector Pulsed Width.
The comments also add that the values greater than ‘1’ will result in a richer mix.
OK, now, this is where the confusion sets in. In my 2014 Dyna I have the TTS MasterTune Calibration: DHA358-01.
In the AE Table at an Engine Temp of 96C it uses a multiplier of 0.48. Doing the sums, if the Base Injector Pulse Width was 10mS for example, then the result would be: 10 * 0.48 = 4.8mS which is a leaner mix and not what one wants under acceleration.
So, where am I going wrong ??
Old 09-11-2014, 07:37 PM
slyedog's Avatar
slyedog
slyedog is offline
If the base cal values are as stated then don't mess with them unless you have a lack of take off throttle response. You are over analyzing a function that you don't want too rich anyway. Take the time you are investing in this and dig more into data logging and adjusting spark tables along with vtuning and your ve tables. Post in the sticky if you want a analytical response.
Old 09-11-2014, 07:52 PM
Fritzables's Avatar
Fritzables
Thanks Slyedog,
No intentions of touching it but I am one of those people who like to understand the operation of the device regardless if I make an adjustment to a certain table or not.
Pete
Steel Steed
19
04-27-2016 06:59 AM
SmittyFXDL
08-09-2012 08:09 AM
Sleeps In Trees
14
11-29-2008 02:27 PM
jpbo
08-29-2008 08:27 PM
ste71
23
10-19-2007 02:22 PM
Quick Reply: TTS MasterTune Accel Enrichment Table ??
