82 XLH Acceleration Issues past 1/2 throttle
First time motorcycle owner, took up possession of my dads 1982 XLH that has been sitting in a garage for roughly 10 years now. I am new to motorcycles and have a good concept of engines and how they work, as well as I like to work with my hands, which makes this bike perfect since I will have a lot to do...
Current progress done on bike:
Plugs changed
oil and filter changed
Gas tank soaked in vinegar and cleaned out
fuel line and filter changed
rear brake replaced(piston was frozen)
brakes bled
Carb rebuilt and cleaned
New battery
Need to do:
OG seat cleaning/restoration
New tires
primary oil change
Good cleaning
replace handlebar bushings
Now the bike runs pretty well(as far as I know). When i am throttling up, past 1/2 throttle the bike loses power and will not rev any higher. My guesses would be something with fuel delivery is off, tank not cleaned enough, there is a little bit of sediment in my fuel filter after a little bit, which could also be causing my carb to get clogged up again. Seems like I could ride 1/2 throttle all day no problem. I have been considering taking it to a shop but wanted to check to see if anybody had any ideas or had seen the issue before my wallet runs dry. Any advice on the bike in general, or additions to To Do list would be much appreciated!
Video of Noise after 1/2 throttle:
Plugs changed
brakes bled
New battery
Need to do:
New tires
primary oil change
Good cleaning
Received 17,622 Likes
EDIT: I had a similar symptom. It would accelerate fine up to about 60 MPH, then it would sputter and die. I would wait a few minutes and it would run fine again for a while then sputter out. I found that the fuel level was set too low. It would simply run out, then fill up again.
Could be the float level is set too low. There is a good picture in the Factory Service Manual 99484-85 thar shows how to set it.
I'm not seeing a carb support bracket on your ride. I think you'll find the general consensus is every Ironhead needs a carb support bracket. aka I'd suggest you fix that.
But back to your problem.....
Tell us about your ignition system. Electronic or converted to points ?
Your description of the symptom(s) makes me think gas or ignition or BOTH. Either can produce what you're describing. Once your gas woes are cleaned up, check your timing with a timing light. And if you've got points with mechanical advance..... there's more involved to get the timing right, so talk to us.
carl
jaystay42
Exhaust System Topics
08-06-2011 08:10 PM
bjhamlyn
08-26-2010 10:51 PM
