Ironhead A place to talk about Ironheads.
Charging
Old Jun 30, 2008 | 11:18 PM
peewee97's Avatar
peewee97
Default Charging
My 77 xlt has developed a charging problem. The gen lite doesn't come on. I put a new reg on and the problem is still there, I can take the cover off the reg and make it lite up by pushing the points closed. The whole problem started when the pos cable shorted against the frame, then I found the nut on the gen drive gear loose. Help. Thanks
Old Jul 1, 2008 | 06:48 AM
mojo2go's Avatar
mojo2go
Default RE: Charging
Find the fuses and check them all.
Old Jul 1, 2008 | 11:57 PM
peewee97's Avatar
peewee97
What fuses? I have tested the circuit breakers
Old Jul 2, 2008 | 05:01 AM
silvergoldsmith's Avatar
silvergoldsmith
Have you tried polarizing the regulator?
Old Jul 2, 2008 | 05:09 AM
bucaman's Avatar
bucaman
You may want to read through my situation under " Charging System Still".
Lots of good info posted from&nbsp\\;the guys. Helped me out greatly.
Bucaman
Old Jul 2, 2008 | 12:12 PM
mojo2go's Avatar
mojo2go
ORIGINAL: peewee97
Ooops, I meant circuit breakers - sorry bout that
Old Jul 2, 2008 | 06:57 PM
peewee97's Avatar
peewee97
polarized the reg several times
Old Jul 2, 2008 | 07:10 PM
piniongear's Avatar
piniongear
You want your generator light TO COME ON?
If it comes on, that means the generator is not producing a charge.
Most of us want that light to never come on because if it does, we have generator problems.
I dunno, maybe I am missing something here......pg
Old Jul 2, 2008 | 07:38 PM
peewee97's Avatar
peewee97
The lite doesn't even come on when I turn the key on
Old Jul 2, 2008 | 08:14 PM
piniongear's Avatar
piniongear
The generator signal light has 2 wires connected in its circuit.
Lets start at the voltage regulator.
I am referring to a 1973-74 wiring diagram, but yours should be the same.
On the 'GEN' terminal of the regulator there should be 2 tan wires. One goes to the generator 'A' terminal and the other goes to your generator signal light. This wire to the light is tan until it comes to a connector, then it is black going a short distance to the light.
Out of the light is a white wire. This goes a short distance to the handlebar area and connects to an insulated terminal that will have 1 white wire and 4 orange wires there on that same terminal.
Make sure these wires are connected up as described.............pg
