I need some advice on a project
There is perhaps 3/8 inch thick crumbly cast aluminum crankcase with the flywheels right there around the plug.
No one, and I mean no one, should ever remove this plug..........pg
Received 1,234 Likes
Well, believe me or not, it's no skin off my nose but that plug is not a drain plug. Check the subject here on the forum to read the sad stories of those who were told, or decided, it was a drain plug.
It gets pointed out time after time - get thee a factory manual. Pull the top end off and inspect everything. At least you'll know what you've got.
.sometimes bikes change from one year to another...sometimes bikes have different problems than another bike..personally i am the guy that would probably try and start it.....cause i couldnt help myself.but i would recomend not to.you might as well take the heads off and take a peek.see what you got.if all is good you can put it back together with no worries.it just cost me 630 for pistons and a bore job plus valves/guides etc if youve rebuilt auto engines you should have no problem working on an ironhead......i had no experience with ironheads 6 months ago....now i have learned alot...mostly the hard way...story of my life..
if you want the bike get it.if not now when?you gonna wait til maybe he drops the price a hundred bucks??if you do 10 years will go by before you actually get one.....life goes like that.---good luck
edit---if you dont want it let us know where its at.might be close to someone.
Here's the thing....most of these old ironheads aren't worth the $ you need to put into them to restore them, even after its been restored. However, what you need to think about is how much $$ is the equivalent of that feeling you get when you're riding. that factor x really does matter. I paid 3500 for my 83 and I think it was a steal, even after I rebuild the engine this winter.
guitarman777
11-28-2006 07:16 PM
