Ironhead A place to talk about Ironheads.
starting problem
Old Jun 18, 2010 | 01:45 PM
EvilWayz's Avatar
EvilWayz
Default starting problem
bikes been setting for about a month without being started. We rewired the bike completely, and now when i go to start it, it backfires and then theres this terrible sound of a gear grinding.
Old Jun 18, 2010 | 09:16 PM
IronMick's Avatar
IronMick
The terrible gear grinding sound is probably the starter system - if the battery has not been freshly charged it will not have enough power to run the starter relay/starter solenoid/starter motor/etc.
If the bike has not started then the exhaust pipes are not hot enough to ignite unburned fuel; so the backfire could be fuel igniting in the combustion chamber when the exhaust port is open - which could be a timing problem. Just thinking out loud here. Is it a points system? Perhaps, if so, a little attention there might free things up. Just guessing.
Old Jun 21, 2010 | 12:00 PM
EvilWayz's Avatar
EvilWayz
i put some scratches on the plate before i pulle3d it out, and its electronic ignition. i guess i ll take a look at it anyways.
Old Jun 21, 2010 | 01:34 PM
carlgrover's Avatar
carlgrover
Sticky valve maybe? Or the exhaust pushrod is adjusted a little too long?
Old Jun 22, 2010 | 12:36 AM
sepixlh's Avatar
sepixlh
ignition timing off 180 degrees = timing rotor placed wrongly
Old Jun 22, 2010 | 09:54 AM
EvilWayz's Avatar
EvilWayz
i dont think its that far off i marked the distributor plate before i opened the3 cam chest up to put in the new seal.
Old Jun 22, 2010 | 02:44 PM
ScootyMcGee's Avatar
ScootyMcGee
6th Gear
single fire or dual fire? maybe double check to make sure the wires are on correctly? the gear grinding could possibly be, if it has electric start, that the starter isn't disengaging correctly.
Old Jun 27, 2010 | 10:12 AM
70Weight's Avatar
70Weight
As I recall You have always had trouble starting,using up the new battery's?
I agree with the timing bein off...alot.
Old Jun 28, 2010 | 12:29 PM
EvilWayz's Avatar
EvilWayz
do i just tighten it down?
Old Jun 28, 2010 | 08:19 PM
70Weight's Avatar
70Weight
Did You use a starter relay with the new wiring harness?
