One more question on the oil pump.....I recently read somewhere that you shouldn't use gasket sealer when using a paper gasket on an oil pump and only sparingly if used. Any opinions on this?
I use Permatex #3 on the oil pump gaskets.
Regarding a question such as you ask, it is always a good idea to follow the factory service recommendations.
In this case, the factory says to use a non hardening gasket sealer on the oil pump gaskets.
Permatex # 3 is a non hardening sealer. Permatex # 2 IS NOT! pg
Permatex copper spray does not harden. Also, like the Hylomar, it is a gasker sealer as opposed to a gasket maker. Name has been changed - people refer to is as Copper Coat, various spellings, but it has a different name now.
